Listening to the radio while car isn't running..
Most cars you can turn the ignition to the first lock where the radio will work and the engine isn't running (without killing the battery). Is this possible on the A4?
RE: Listening to the radio while car isn't running..
yup it does the same on my car. if i have the radio on and i shut the car off all i gota do is hit the on/off switch to turn it off then hit it again and the radio turns on. the gauges and everything are not on but the radio is. the subs in my car will not work tho. for that you gota put the key in the on position. its great when your trying to be discreet in the car and not have any lights on. that combined with tint and you are set
