lean in bank 1
lean in bank 1
i got the car about a month ago, and poped the hood to check the filter and just really look around well i didn't put the airbox outlet hose on tight enough so i got a code lean in bank 1, drove it a time or 2 and the light went off, well i am driving tonight and it is back on, wtf?
RE: lean in bank 1
I would pull the battery cable for a minute or two to reset the ecu. if it comes back, get it read immediatly because you have a problem somewhere.
If it doesn't come back, then you're good.
The best option would be to get it read, then cleared, but this works if you dont have the means to easily do that.
