Leaking washer fluid
Old 06-27-2006 | 09:28 PM
apg96's Avatar
Default Leaking washer fluid
So the hose that comes our of the washer fluid resovior is just cracked and old and needs to be replaced. Everytime i add washer fluid it leaks until it gets to about 2/5 of its capacity. I had once tried to get it fixed when the mechanic was working on my car but having them just put a new hose on while the car was up but they didnt not have the right size and they were doing it for free so they didnt bother.
Where can i find out what the right size is for this, how long it needs to be and maybe a how to replace it.
The mechanic didnt seem to have a problem once it was on the lift, so i might go get an oil change and have him do it then. (thats how they let me use the lift).
Old 06-27-2006 | 11:36 PM
acetrebo's Avatar
Default RE: Leaking washer fluid
I would just drain the washer fluid out, and remove the hose completly so you can see what size/length.
Heck, take it with you when you go buy some new tubing at the store.
just my 2cents.
Old 06-28-2006 | 12:50 AM
david9999's Avatar
apg96, havent seen you posting in a while.
Old 06-28-2006 | 01:24 AM
apg96's Avatar
hahaha the past 12 days ive been in Europe, in OTF there are a few post about it, one from yesterday when i got back, pics to come.
Old 06-28-2006 | 02:10 AM
Bip's Avatar
Bip
my headlight washer leaks and its pissing me off cause i dont know how to get to it and i never have any washer fluid
anyone know what to do?
Old 06-28-2006 | 04:23 AM
apg96's Avatar
dont try to steal my thread
Old 06-28-2006 | 10:01 AM
david9999's Avatar
Find the leak. It is unusual for the hose to crack and leak, It is usually either a crack in the reservoir, the pump, or the headlight sprayer.
Old 06-28-2006 | 03:11 PM
onepoint8tee's Avatar
Make sure its not leaking from the pump(s) that sit in the resevoir. Thats the most common place for a leak. The plasitc housings for the pump that slide into the resevoir gets rotted/cracked... I just took em out, appoxied/rubber cemented them and wrapped them up in electircal tape. Its been 6 months and so far so good.
Old 06-28-2006 | 03:45 PM
Bip's Avatar
Bip
it was just a question and i already posted one and no one answerd
Old 06-28-2006 | 04:41 PM
apg96's Avatar
i have found the leak, its coming from the house just a lil to the driver side from the center of the car. I have tried to wrap it with some duct tape but as soon as i filled it up again it started leaking.
Stearnsy
05-05-2013 07:12 PM
loyolacub68
08-23-2011 07:00 PM
TheDavey
04-03-2009 12:44 AM
chief
05-22-2008 03:37 PM
vrso2
05-13-2007 06:07 PM
