lag GT or T3 or T3T4 ...
#41
RE: ATP graphs accurate? GT28RS, GT2X, K04
.48 is a t3 housing and is the same as a t25 .64 housing
t3 To t25
.48 ~= .64
.63 ~= .86
also if you had a smaller 28rs turbine the flow would suck and power would be far lower.
t3 To t25
.48 ~= .64
.63 ~= .86
#42
I know it can't be purchased like that, but was suggesting what might work.
I've heard ofmaking a'custom' turbo with T3 .48A/R hot side on a GT3071R, for quick spool and maybe upto 350whp. If willing to sacrifice some top end revs then maybe could improve spool time on gt28rs.
#43
Hi been a while since posted. Anyway had further discussions with Tyrolsport and it would suit my tastes to finallygo with a T3/t4 Super 40 with .48 Exhaust, Stage 1 exhaust wheel.
Am told T3 60 and T3/t4 40are very similar, but the40 and super 40 from turboneticsare more efficient.
Thanks cincyTTfor help with turbo info, this thread should help alot of aspiring Audi turbo fanatics.. lol
#44
Hey cincyTT are you still about?
do you think that a aftermarket exhaust is a necessity for BT like the t3 super 60?
obviously I'd use a high flow cat and maybe larger downpipe.
#46
2.5" is plenty for cars making 300awhp. The larger exhuast will spool the turbo faster and make more power in boost. If you can get your hands on a 3", you can do that also, should only gain a few more hp, and add more sound.
#47
how big is the standard exhuast? I guess K04 wont need bigger than standard, but I'd put a hi flow cat in.
I'm wondering about either going BT or K04, for financial reasons, the clutch replacement for BT is costly, but I wonder if I'll have to change the clutch anyway just for general maintenance..
#48
Stock is 2.1", which is still restrictive for any turbo car. Im not sure the few extra hp form the k04 would cause you to need a new clutch or not, but since 100 people have done it before, that answer should be on here somewhere already
#50
if you go without BB, would you go bigger than a t3 super 60 spec? I'ma bit sensitiveto the lag issue as I have quattro. I wonder how t3/t4 would compare to a GT28RS?
