Sponsored by:
Sponsored by:
KO4 Turbo with Stock chip?
Old 09-18-2007, 12:53 PM
docurley's Avatar
Default RE: KO4 Turbo with Stock chip?
Hay if you like I will swap you a K03s for a K04-15 then you have no issues at all.
  #22
Old 09-18-2007, 03:46 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: docurley
So you can basically have the same turbo? The dimensions are almost identical, thus only an increase turbo rating of 15hp.
  #23
Old 09-18-2007, 03:49 PM
cincyTT's Avatar
I'm make believe
ORIGINAL: akielb
Its just stupid to run a k04 on stock tuning if you have no intention to ever upgrade your tuning. It would be like spending a bunch of money and getting N20 installed and not installing the shot button.
Only thing the ko4 chips do differntly is push the turbo 8-10psi out of its effiency and add more fuel. You could get the same results running a ko3 to 26-28psi and adding a fpr or 310cc injectors and larger maf like these chips do. Its really not that complicated
  #24
Old 09-18-2007, 03:51 PM
kolan67's Avatar
is a larger maf and a fpr necessary when giac-ing (big injector w/ dv)?
doesnt giac big injector run at 18-20 psi? where does this 26-28 come from..
I'm noob, i know.
  #25
Old 09-18-2007, 03:57 PM
cincyTT's Avatar
I'm make believe
Im not sure on the names but one file runs a 5bar fpr and ~26psi and some others use massive overkill 380cc injectors and still at 4bar, and another tune uses 310cc injectors. The 5bar or is more than enough and can be tuned easier, even with a vag and lemmiwinks
s4noob
9
06-24-2008 02:41 PM
Masterkiller
10-29-2007 05:02 PM
Poopie
10
02-12-2007 11:24 PM
ckandes1
10-26-2006 07:26 PM
ricehead
11-04-2005 10:59 AM
Quick Reply: KO4 Turbo with Stock chip?
