Sponsored by:
Sponsored by:
killing DRL's!? (daytime running lights)
Old 06-06-2007, 08:12 AM
ironman's Avatar
Default RE: killing DRL's!? (daytime running lights)
Ya vagcom it but your going to cahnge everything to standard your time your speedo and mileage. jsut be aware of taht so you get all confuzzled after you get in the car
Old 06-06-2007, 08:48 AM
CLX's Avatar
CLX
CLX is offline
Zombie Defense Force
You're wrong, they are just as helpful in the daytime. People don't seem to realize how easilly cars can disappear in broad daylight, especially when they are in your mirrors.
Old 06-06-2007, 10:57 AM
2k S4's Avatar
I have a Canadian spec car, & the DRL's bothered me so much!
You can't Vag-com a B5 lights, just the HID auto-leveling.
There are 2 relays under the lower dash that need to be pulled. One does the amber parking lights, & the other is the headlights. After you pull the relay, you just jumper one of the terminals to get the headlights to work on the switch.
Option one, Simply remove the relay (214) from position #8 (as printed on the relay panel). This will prevent the corner lamps and the taillights from coming on as soon as the ignition is turned to the on position
Option two will disable your headlights, and leave your corner lamps and taillights to come on when the iginition is turned to the on position. First you need to make a jumper. Take two spade connectors and connect them with a very short piece of solid (as opposed to liquid?) automotive electrical wire. Second, pull out the relay (209) from position #9. Take note where contacts A and B are on the relay, and place the jumper you've just made across the sockets where contacts A and B would have been. You must use the jumper in order for the headlights to remain operational.
Option three is definately illegal. It will completely disable your DRL system. Perform both option one and option two, and the entire system is disabled.
redmond1501
05-23-2012 04:04 PM
R Smith
B7 Models
06-25-2011 02:56 PM
huggybearv1
11-08-2010 10:53 AM
billsa3
11-16-2009 12:55 AM
vtchaz
05-25-2004 05:41 PM
Quick Reply: killing DRL's!? (daytime running lights)
