Key locked in ignition
Old 07-22-2006 | 08:15 PM
ejc317's Avatar
Default Key locked in ignition
I put key in - i tonly turns 1/5 of the way and won't go ....
i finally decide to risk it and turned it really hard and it finally starts - then its fine after that
is there any problem i should be concerned with
Old 07-22-2006 | 08:28 PM
Dj Spiel's Avatar
Default RE: Key locked in ignition
when you put your key in try jugglign the steering wheel a bit.
Old 07-22-2006 | 10:35 PM
ejc317's Avatar
wel the 2nd i forced the key the steering wheel spun a bit
Old 07-23-2006 | 10:43 AM
david9999's Avatar
Sometimes the steering wheel lock puts pressure on the ignition. Turn the wheel at bit and with the wheel held there try the ignition again. This usually works.
The other cause of this is a worn ignition lock or worn key, in which case moving the steering wheel will not solve the problem.
Laurel
09-06-2011 05:07 PM
mack010s4
11-30-2010 10:07 PM
Audi858
03-27-2008 03:55 PM
Sichko
01-28-2006 12:33 AM
Mikem
06-06-2005 12:46 PM
Quick Reply: Key locked in ignition
