the K04 project begins again..... have questions and need comments!
#22
RE: the K04 project begins again..... have questions and need comments!
hey khj677turbo, in your sig it says you have the neuspeed turbo intake hose.... do you think it makes any difference? Do you recommend buying it? and any support for a website to buy it would be awesome!
#24
ORIGINAL: Lazer Viking
yes to the 7e plugs
yes to the t.i.p
labree has a cheaper hfc
ecs has rs4 mounts, i think
abd the greed speed snub is alot cheaper (and wont need trimming)
what file are you getting for the k04 ?
and you should ask giac what size injectors they reccomend.. i think it may be the tt225 injectors
yes to the 7e plugs
yes to the t.i.p
#25
I dunno, i bought it when i had the ko3, and it blew *** to install since the rubber washer on the metal adapter to the turbo wouldnt go on for a while even with oil. I think the idea behind it is better, its alot smoother of an intake tube then the stock just by looking at it. Notice a difference, not really. NO matter what i do it leans on the headlight housing and looks to bend the hose. If you wanted to worry about it and think you need one, i think apr has a similar one for 100 less or so. 300 is alot for a hose.
#26
Also just realized taht you didnt list an n75, i suggest you get the h version, i installed mine after i had the ko4 in for a while. and it holds much much better, and its also cool to see the needle on the boost gauge go past the 25 mark and hold haha.
#27
nice.. i didnt even think about that. Where can you buy the n75 h version from, i cant seem to find it. Ive read on some forums certain n75's will put your car in limp mode....is that true, or only with minumum modifications
#29
http://www.tyrolsport.com/vwperformance.htm
where i got mine. i get limp mode when i go into redline. so i dunno.
#30
yah i got off the phone with GIAC the other day and they recommended 380 cc injectors... i never have heard of this size before. They said that they sell them and its $300 for all four... does that seem kinda pricey? it does to me
