K04/PC-16 Another Problem/Question
#53
RE: I AM GOING K04 FOR REAL THIS TIME!!!!
Yeah I will just pick up a funnel tomorrow morning along with a thing to put oil in. I have a bunch of tutorials/DIY's that I have found that I will be using. I am going to mark everything so I know where it all goes back when I install the new one. I know my way around the engine bay really well so I shouldn't have a problem. PLus I can look up online on ETKA or whatever its called.
Josh
Josh
#54
The day has arrived! It's 9:30 and I am about to go pick up the oil catch pan thing and then I will start on this project. I went out earlier this morning and soaked the bolts in PB blaster so hopefully it won't be to difficult to get them out. Also I am going to be fixing my coolant leak (coolant flange on the back of the block). I will give you updates throughout the day!
Josh
Josh
#55
Here are some pictures of all the hardware!
All the parts.
Bosch 310cc RedTop Injectors.
034 Motorsports AFPR and Fuel Pressure Gauge.
Coolant Flange
And now it's raining outside and I don't have a garage to work in, just a car port... Hopefully it will slow down here in a bit.
Josh
All the parts.
Coolant Flange
Josh
#57
YEAH!!!! Firs part is done! The turbo is out and now I am taking a break and then putting it all back together again! This is slightly more difficult than I though it would be. THat fricken turbo mount bolt was a pain and the one nut under the cat sucked to. Then I couldn't figure out what was going on and then realized that the coolant return line was bolted to the turbo itself. Once that came off it was pretty easy. I have been taking pictures and stuff and will post those all tonight.
Josh
Josh
