K04/PC-16 Another Problem/Question
#171
#174
RE: I AM GOING K04 FOR REAL THIS TIME!!!!
ORIGINAL: FasterA4ThanUrs
is it me or did the pc16 0-60 vid take 10 seconds... i really think i counted 10 seconds on that but i only played it once...
#175
LOL, yeah it is 9 secs actually. And yes I was way over weighted. I am going to go out and try again sometime soon. What should I be able to get w/the tip tranny?
josh
josh
#178
Ok, another problem that I am getting now...
Almost every time I try to start my car now when it's cold it won't start unless I press the gas pedal down. And the boost thing is getting annoying to. I am going to switch to the N75 valve tomorrow and see if that fixes it. Also how do you tell if the spark is being blown out by the boost? I have my plugs gapped to .030. Would that cause problems? Thanks. i really want to get my car running really well!
josh
josh
#179
Josh, your dv might be causing your jump in boost. I had an extra vf engineering one laying around that i put in for my hyperboost, and the car would spike and also would just jump to full boost often when i intended it not to. Im running the race n75 and it seems to do the job, when i go half throttle you can hear a loud hissing when the valve is trying to regulate the boost. It holds pretty good at 10 to 15 as i want.
By the way, seems that my thermostat sensor is the obvious choice for my misfires, running rich and such, hopefully the next time i go home i can do my much needed timing belt, change the sensor and hopefully have a fully working setup ( for the first time!)
As for the startup i cant really help you there, could be a coding thing? Sometimes my cruise control wont work right away, so maybe theres a small glitch in the programming. Dunno what to tell you.
#180
Thats kind of what I thought to. But I am not sure. Would it be that the spring in there is to soft? Maybe put the next one in there? I am going to try the N75 thing tomorrow to see if that helps. It's really annoying trying to pass someone and sometimes just not having the power. Sort of scary to!
Hopefully you get your setup running to!
Josh
Josh
