k04 with 440cc injectors
I've been searching the forums forsetupsfor k04swap for the 1.8t engine, and it would be nice to see your setups. And what the gain in hp and tq was.
Mine setup
K04-15
440cc injectors
FMIC
3" exhaust with race cat
to onlything that remains is the biggest thing, and that is the software tune..
Mine setup
K04-15
440cc injectors
FMIC
RE: k04 with 440cc injectors
why do u have 440cc injectors? unless your going with an aggressive file stock injectors are fine. pc-16 only uses 310cc and the other aggressive files use about the same. are you running the k04 on your k03 software?
ORIGINAL: mm
well I dont think thats a problem.. a larger maf housing will do the idle work in worste case.Well well I'll see and come back when it's tuned.
