Sponsored by:
Sponsored by:
K03 boosting- - more? ? ?
Old 12-04-2006, 03:51 PM
Dj Spiel's Avatar
Default K03 boosting- - more? ? ?
Is there a way to get more boost out of K03 without
chipping/etc/etc
I am getting 5PSI
Would boost controller help?
Old 12-04-2006, 03:56 PM
Lazer Viking's Avatar
Default RE: K03 boosting- - more? ? ?
no, not unless you get an adjustable fpr as well, can change the n75 for a more aggressive one thats like 1-2 more psi, and i've heard of tightening the rod in the wastegate to make it hold a little more... but in short, not really
Old 12-04-2006, 03:58 PM
Dj Spiel's Avatar
https://www.audiforums.com/m_143133/tm.htm
Old 12-04-2006, 03:59 PM
new2me's Avatar
I would think that you will lean out since your adding more air and not more fuel or the right amount of timing advancement which would be done by the programing.
Old 12-04-2006, 04:03 PM
Dj Spiel's Avatar
fpr & bigger injectors would fix that wouldnt it?
Old 12-04-2006, 04:04 PM
yes, but for the price of an fpr and bigger injectors you could get chipped
Old 12-04-2006, 04:05 PM
Karl's Avatar
well if stock is 8-11 and you are pushing 5.. then yeah you can up your boost.. the way to do this is find the source of the leak, and fix it should allow you more boost (up to the stock levels) but dont try to exceed those levels if you dont have a way to get more fuel in there.. otherwise that baby will run so hot it will go KABLOOEE
Old 12-04-2006, 04:08 PM
new2me's Avatar
hmm i dont think so something needs to control timing and after all is said and done it would of been cheaper and easier to just get chipped.
Old 12-04-2006, 04:10 PM
Dj Spiel's Avatar
well i been running 5psi ever since i installed boostgauge
Old 12-04-2006, 04:14 PM
new2me's Avatar
Are you saying that after the gauge install there was a loss of power/boost?
ORIGINAL: Dj Spiel
Quick Reply: K03 boosting- - more? ? ?
