Just installed a N75J, but I'm only getting 10 pounds of boost...
There are no leaks so I'm wondering if it's suppose to be like that or am I suppose to reset the ECU by way of disconnecting the battery for 30min.
RE: Just installed a N75J, but I'm only getting 10 pounds of boost...
Did you install it like this?
The long nipple goes in the turbo inlet pipe.
Then, the nipple pointing away from the inlet pipe connects to the wastegate.
The last nipple gets connected to the turbo compressor housing.
