Sponsored by:
Sponsored by:
just experienced a weird issue.. possible problem? need input..
Old 04-24-2006, 10:12 PM
north5995's Avatar
Default RE: just experienced a weird issue.. possible problem? need input..
Hummm maybe i should swtich back to a 710N as well.... what does your WOT look like? I can do 21PSI with the green spring, 15PSI with the blue.
  #22
Old 04-24-2006, 10:49 PM
A4 the Quattro's Avatar
ive never tried the green spring.. its the weakest spring.. you would think that it woud give the least boost.. hmmm.. i only get like 16psi max with the 710N .. ill probably switch back to the Forge tommorrow and check out the green spring..
  #23
Old 04-24-2006, 11:22 PM
anyone think this could possibly cause the problem? ya the car is running awesome with the 710N .. but i also cleaned off this plug before i put it back in:
  #24
Old 04-25-2006, 12:36 AM
2000A4Turbo's Avatar
any check engine lights?.... maybe a oil ring issue....or possible timing due to a fuel problem???? could be wrong...couldnt hurt to check the injectors.
choppedelight
10-18-2010 12:36 PM
cerealkilla1980
02-23-2010 10:18 AM
pete7
10-30-2008 11:23 AM
FP of belle ville
02-16-2008 08:13 PM
Quick Reply: just experienced a weird issue.. possible problem? need input..
