Just Bought Audi, and got check engine light
Old 05-24-2012 | 07:42 AM
Jchockey100's Avatar
Alright then time to check breather hose and purge valve.
Old 05-24-2012 | 01:05 PM
AudiSline12's Avatar
Banned
You just bought yourself a lemon. Good luck. Most Audis are lemons after 50,000 miles. Should've gotten yourself a Toyota.
Old 05-24-2012 | 01:23 PM
Banned
You just bought yourself a lemon. Good luck. Most Audis are lemons after 55,000 miles. Should've gotten yourself a Lexus.
Old 05-24-2012 | 07:58 PM
Mario009's Avatar
DAMMMMMMMMMMMMMMMNNNNNNNNNNNNNNNN.... LOL. Probably did. If when i change the coil pack and check and change the sensors that are bad, i will be pissed the hell off i didnt buy a mercedes or bmw lol.
Old 05-24-2012 | 10:09 PM
ImTheDevil's Avatar
First off, ignore the troll. Second, misfires on all 3 cylinders of bank 2 (driver side bank) would seem to say the cam sensor is bad (although it usually throws a code regarding threshold not reached, or cam over/under advanced), or the timing jumped a tooth. Do you have a record for the car having its timing service done? If not, you need to do this immediately as the car is significantly beyond the time when it is due. Bank 2 sensor 2 is the post-cat O2 sensor on the driver side and has only a remote chance of having any bearing on the misfire. And it's unlikely that your coil pack is bad - the individual coils on the 1.8T fail a lot but the 2.8 coils rarely have issues.
Old 05-25-2012 | 02:52 PM
Mario009's Avatar
Man thanks a lot. See its people like you who help others that keep members part of this/all forums.
I will definately check the records for the timing asap.
Old 05-25-2012 | 08:49 PM
bigdadi's Avatar
if timing off / jumps then the engine will be shaking, trembling. If it is not shaking then should be sensers.
  #18
Old 05-25-2012 | 09:24 PM
ImTheDevil's Avatar
It should but there's a chance it won't if it's only off by one tooth.
AutoAnna
07-10-2015 04:06 AM
shawn2444
02-18-2015 10:17 PM
toy4two
02-15-2012 07:52 PM
MrTigz5254
03-07-2008 11:56 PM
blaze420
10-05-2007 12:13 AM
Quick Reply: Just Bought Audi, and got check engine light
