Instructions on removing radiator/support for a timing belt change...
Can anyone supply me with instructions on removing the front end of a 99 a4 2.8? I need to change the timing belt so the radiator and the support need to be removed but I don't have a repair manual yet.... And if at all possible ...does anyone have instructions available on doing the actual timing belt change? I would appreciate any input! Thanks
RE: Instructions on removing radiator/support for a timing belt change...
http://www.audiworld.com might have something, although i don't see timing belt info for the 2.8 there. Try a google search. btw, for the bumper, push down and pull away from the car to disconnect the sides.
good luck,
good luck,
Site_Administrator
09-19-2016 12:56 PM
