Installing Downpipe. Tips?
Old 07-13-2007 | 11:16 AM
ballswell's Avatar
Default Installing Downpipe. Tips?
Finally getting around to installing my test pipe tomorrow. Does anyone who has been through the proceedure provide some tips?
Old 07-13-2007 | 11:30 AM
Black_97 A4's Avatar
Default RE: Installing Downpipe. Tips?
does the test pipe take the cat out?
Old 07-13-2007 | 11:39 AM
CLX's Avatar
CLX
Zombie Defense Force
Yes, test pipe is for cat deletion
Old 07-13-2007 | 04:54 PM
Boostfed13's Avatar
Soak every nut and bolt with WD40 the night before you do the install. Remove the passenger front wheel and the CV axle heat shield to access cat to DP bolts. Trick on of your friends into helping you. Have Band Aid's ready for you knuckles and some cold beers for when you get done enjoy.
Old 07-13-2007 | 05:22 PM
chaos92287's Avatar
soak all the nuts with pb blaster (works better than wd40) and prepare to curse a lot. the tp/dp bolts are a biatch to remove. best way i found was to get them from underneath the car with a socket-8" extender-and a flex joint at the end. its hard to generate enough torque to get the bolts loose tho (hence the reason for the pb blaster)
Old 07-13-2007 | 06:21 PM
Slowb5's Avatar
its a hellish experience...prepare for the worst. but its do-able.
Old 07-13-2007 | 06:33 PM
96audia4's Avatar
Since my cat/dp bolts were completely rusted, I found it easier to disconnect the downpipe/cat from the rest of the exhaust and then mavuever down it to where I could reach the cat/dp bolts better. I also had to use a grinder b/c the bolts just would not budge.
Old 07-13-2007 | 06:40 PM
Amze's Avatar
Good luck..
I'd rather pay a dude like 20 bucks at some grudge shop to do the dirty work... haha
Seems like a huge pain
Old 07-13-2007 | 07:57 PM
aRIf's Avatar
best tip i can give you is let someone else do it. it's pita to take cat out.
Good luck if you're going to do it becuase you'll need it a lot
KSaudiS8
08-14-2015 09:27 AM
mattrazzo
02-20-2011 03:44 PM
KingJames
03-23-2009 03:16 PM
kwik_shift
02-26-2008 04:05 PM
Sp33d07
03-07-2007 03:46 PM
Quick Reply: Installing Downpipe. Tips?
