Sponsored by:
Sponsored by:
Installing Coilovers failed
Old 07-22-2007, 02:27 PM
Borden's Avatar
Default Installing Coilovers failed
well howe and i tried to install the coilovers but we were stopped by one bolt that was freaking impossible to get out soo now im looking for a shop to install them for me.. Audi 1 Borden 0
Old 07-22-2007, 02:30 PM
AteUrV8's Avatar
Default RE: Installing Coilovers failed
it was probably rusted in there.... before you take it to a shop i would spray that thing with some wd-40 and let it chill for a while and than see if it will break loose.
new2me's Avatar
What bolt? Any pic of it?
Old 07-22-2007, 02:37 PM
a4BRZLowrider's Avatar
the lower bolt that holds the shocks??? contorl arms????
Old 07-22-2007, 02:38 PM
Borden's Avatar
It's the bolt holding the upper control links and its very very rusted we couldnt even budge it
Old 07-22-2007, 02:42 PM
new2me's Avatar
Lot's of lube. If that dont work and impact wont fit then break out the torch and heat it up.
Old 07-22-2007, 02:58 PM
Borden's Avatar
im a little hesitant to heat it up becuase there is alot of rubber around it
Old 07-22-2007, 03:04 PM
new2me's Avatar
That's a good point!
Go to your local store that sells tools and get this. http://www.jcwhitney.com/webapp/wcs/...atalogId=10101
Old 07-22-2007, 05:09 PM
Borden's Avatar
thanks new2me ill look for that tomarrow and try again hopefully this time i will be sucsessfull
Old 07-22-2007, 11:49 PM
if u turn the wheel the bolt will be in a straigth position for u to hit....just bang the lil ****** out....u'll need new ones later
Quick Reply: Installing Coilovers failed
