Sponsored by:
Sponsored by:
installed the giac chip!!!
Old 04-24-2007, 08:29 PM
daesharacor's Avatar
Default installed the giac chip!!!
Hey guys-
Just installed the giac chip and took it for a spin... holy torque batman!
It was pretty much exactly what I figured it'd be. VERY torquey, but dies off in the upper rpm range. Overall, definately worth the 400 bucks.
That being said, a week or two ago I posted a picture of my hp/tq curves using the dyno-scan software on my palm. I realize that this method is not completely accurate, but its ok, it's a good comparison to the numbers I have now.
I imported the new runs into excel, averaged them, and superimposed the graph with the stock file graph. What do you think?
Old 04-25-2007, 01:32 AM
chaos92287's Avatar
Default RE: installed the giac chip!!!
the horsepower gains should be higher. you should be running ~190hp with GIAC.
same thing with the torque. should be way higher
Old 04-25-2007, 01:37 AM
miked's Avatar
Yeah those #'s look a little low, but it could just be the software.
Old 04-25-2007, 02:19 AM
so what about the stock numbers? do they look low? if so, it's just the software.
if not, then why wouldn't I be getting all the gains? I replaced the dv with a 710n, i've got a small exhaust leak between the turbo and the cat, and thats about it. Any thoughts?
As for the actual numbers, I'm going to a real dyno this weekend so we'll see.
Old 04-25-2007, 02:25 AM
acetrebo's Avatar
What other mods do you have?
If you want it to last longer into the higher rpms, you need an aftermarket exhaust, a testpipe or high flow cat, anda higher flow intake filter. That will keep the power going into the higher rpms. Fix that exhaust leak too, thats bad because the exhaust is what powers the turbo, so if you have a leak there, its hurting performance.
Old 04-25-2007, 02:32 AM
AteUrV8's Avatar
exhaust/hi flow cat/k&n filter will give you another 20-30hp.
Old 04-25-2007, 04:52 AM
matthias2986's Avatar
i got a k&n filter the other day, whats the ave. gain on that?
Old 04-25-2007, 10:52 AM
Amze's Avatar
Not a lot.. stock airbox has good flow. Get a testpipe and full cat-back exhaust to put yourself near 200hp daes
Old 04-25-2007, 03:47 PM
thanks guys. i'm looking in to a test pipe at least, i already have a k+n.
Old 04-25-2007, 03:52 PM
NuYorka103185's Avatar
get an N75J also, it made my car much quicker and boost better
Quick Reply: installed the giac chip!!!
