INSP
Old 07-14-2003 | 09:11 PM
rpacobra's Avatar
Default INSP
under my tach on the odometer it reads INSP (which i assume means inspection) Is this just another milage tripped indication or is it something i should worry about. It just came on when i moved my car to wash it then goes away after the engine has ran for a minute.</P>
Old 07-14-2003 | 09:53 PM
brrman's Avatar
Default INSP
just another reminder. You can permanently delete it (until the mileage trips it again - I think at another 10K or so) but its a diff process for certain models. You have to use the small dash gauge *****/sticks.</P>
If the car is a 98-up push and hold the button on the right in the gauge cluster. Turn key on. Let go of right button, and pull left button and let go. Display should show "---", now push button on right in again. Display should show "insp", now pull and let go of the button on the left.Turn key off. Cycle key back on. Odometer should no longer display the reminder. </P>
Man, it took me a dozen tries to get that to work, but eventually I got it.</P>
Old 07-15-2003 | 05:01 PM
rpacobra's Avatar
Default INSP
thank you. It is a relief to know there isn't anything wrong with my car. Thanks for the reset info.
isreal13
12-06-2013 08:31 PM
Polka Salad
04-18-2011 08:44 PM
Rusci53audi
12-08-2010 10:21 PM
lolo22
11-01-2010 05:26 AM
Nicka430v
04-10-2009 01:59 PM
