Sponsored by:
Sponsored by:
Im doing clear corners and i need help URGENT??
Old 07-10-2005, 01:04 AM
YFZFourFifty's Avatar
Default Im doing clear corners and i need help URGENT??
I am stuck at the very begining.. How do you disassemble the wire housing that connects to the back of the headlight?
I pulled and wiggled it and it isn't comeing loose???
Old 07-10-2005, 01:29 AM
Jestnomen's Avatar
6th Gear
Default RE: Im doing clear corners and i need help URGENT??
Are you talking about the wire piece that holds the bulb in? it slides to the side then hinges out.
Old 07-10-2005, 01:31 AM
ackjazz's Avatar
They do come apart...you have to stick a screw driver in the clip part and pry or pull. They are just stuck together hard. I had the same challenge and was afraid I was going to break something, but it turned out fine. It just took a little muscle. Good luck!
no the 10 or so wires that power the lights to turn on. Its probably simple but i have no clue how to unplug it???
Old 07-10-2005, 02:18 AM
ackjazz's Avatar
The part that plugs into the outside casing is about the same length as the outside casing itself. Work it enough and it will finally pop apart.
Old 07-10-2005, 03:50 AM
Dave666's Avatar
Yes , I had ALOT of trouble with one of those .
The first one came off easy . The second one took me half an hour , lol .
Old 07-10-2005, 03:55 AM
AUDI05's Avatar
this are the same reasons im tedious about doing this, however ill do it like when my dads out of town
Old 07-10-2005, 04:03 AM
Dave666's Avatar
Why ?
Would he spank you for doing anything other then driving the car ?
Old 07-10-2005, 10:05 AM
lidonnit's Avatar
LOL.... Hahahaha. Just work them... dont force them too much they will eventually come apart as the frustration builds.
Old 07-10-2005, 02:31 PM
Thanks a lot. I eventually stuck a screw driver in and somthing must have clicked and it poped out so easy. Its somthing that you have to experience before you do it or else you will be thinking that your going to break it.
This is the easiest mod to do to your car. It looks great too. Im going to do my uncles and my friends for a little $$. haha
ill post pics when i get them.
Sheasta
07-18-2012 07:08 PM
mike step
01-07-2010 10:29 PM
FezA4
11-04-2007 12:32 PM
a88fl1
06-28-2007 04:50 PM
blake00
06-10-2006 04:28 PM
Quick Reply: Im doing clear corners and i need help URGENT??
