Idle Problem. . . Any ideas?
WhenI start my car in the mornings or whenever it has been sitting for a while (20+ minutes) it has this horrible idol problem. It idols at around 1100 instead of 900like it should for about 2 or 3 minutes, and i hear a loud high-pitched noise from under the hood (usually it does, sometimes it even goes up and down from 1500 to 500). After a few minutes I hear this sound like its winding down and then it idols perfect.
I really do not have any ideas, so any input is appreciated.
Thanks
Thanks
RE: Idol Problem. . . Any ideas?
Yeah, a vacumn leak was my only guess too.
How do you check for a vacumn leak? YeahI actuallydid run it for codes becausemy check engine light comes on periodically, anywaysI got 4 different codes. . .
2 clyinder misfire codes
- general misfire
-cylinder 1 misfire (i did regap my spark plugs, seemed to help)
fuel system running to lean
can't remember the other one
(i'm at work ehh. . . )
- general misfire
haha thanks, I have checked almost all the hoses, atleast all the ones that I can access by simply popping the hood, however i have not gotten under the car or gotten too deep into the engine bay. . .
is there a typical place for the B5 1.8TQ to have vacumn leaks?
ORIGINAL: Audi A Fizzle
Alright, thanks for all thehelp so far!
ps. headshok i saw some photos of your car in some other posts, sexy as hell man!
But yeah, as for your possible boost leak... the hose I mentioned is usually pretty obvious when it's leaking. Rig up a temp boost/vac gauge and run the car. Shops can usually do a 'smoke' test for about half an hour's labour.
Your high-pitched whine could possibly be your secondary air pump. To fix that properly, it's expensive. I'm deleting mine. Wait what year is your car? I think SAP's were only on 2000+.
