i need help fitting a dump valve blow off valve bov please please please
hi there everyone
i have just bought a baileys dump valve and fitting kit..
and they send me NO instructions so i am really stuck..
so if anyone can please help and some pics of fitted ones would be a help too
thanks everyone[:@][:@][:@][:@][:@]
RE: i need help fitting a dump valve blow off valve bov please please please
do you got the right flange?? whats the "fitting" kit?? is it by any chance a hose that blows the air back into the intake, if not than your car is gonna run like crap...
just be prepared to have some trouble with your catalytic converter later in your cars life, and also be prepared to have some runnig problems with your car... but if you really wanted the bov... to each his own... im not gona knock you for it... check with the company you purchased it from... also does it mount to a flange or does it mount though the stock dv location?
ok, do you know where the stock dv is???
the valve you got, is the kit so it will fit an audi??
is there a C clamp??
you have to get the fit kit on the bov
then find the stock dv.....yes you have to pull the belly pan
then remove the stock dv
plug the return line(the one going back to the intake)
install the bov and run new vacume hose from the intake to the bov(follow the old line)
that should do it, sounds simpler then it is...
if you have more questions....ask
E
E
