I NEED HELP.. EXPERTS PLEASE !!!
people im getting these error codes
what could they mean?
Control Module Part Number: 8D0 907 557 C
Component and/or Version: 1,8L R4/5V MOTR AT D07
Software Coding: 04031
Work Shop Code: WSC 06335
6 Faults Found:
16515 - Oxygen (Lambda) Sensor B1 S1: Signal too Low
P0131 - 35-00 - -
00561 - Mixture Adaptation
15-00 - Adaptation Limit (Add) Not Reached
17734 - Knock-Control: Cylinder 2: Regulation Limit Exceeded
P1326 - 35-10 - - - Intermittent
17735 - Knock-Control: Cylinder 3: Regulation Limit Exceeded
P1327 - 35-10 - - - Intermittent
17733 - Knock-Control: Cylinder 1: Regulation Limit Exceeded
P1325 - 35-10 - - - Intermittent
17736 - Knock-Control: Cylinder 4: Regulation Limit Exceeded
P1328 - 35-10 - - - Intermittent
any help appreciated...
6 Faults Found:
P0131 - 35-00 - -
RE: I NEED HELP.. EXPERTS PLEASE !!!
Upstream O2 is reaction time is to slow, might need a new one
Scann its movement on Vag com see if it changes fast enough
Run a higher octane Gas and clear codes
It might be a bad Knock sensor as welll
yea i just replaced it the old one wasnt working at all, now as soon as i replaced it with a aftermarket one, it says signal too low
do u think i was given a dud?
and would this be under manufacturer
