Sponsored by:
Sponsored by:
I just installed my k04 Turbo at home!
Old 12-09-2007, 08:55 PM
blake's Avatar
Default I just installed my k04 Turbo at home!
I just finished today my neuspeed k04 kit install( with out the software ). It to me about 8 hours total, just because i live 30 min from town. The car feels so fresh and quick, the turbo i took off had 130k on it the the wastegate arm floped around freely. I think if i can install this any one can, thanks to info found on the web.
Old 12-09-2007, 09:18 PM
A4speed's Avatar
Default RE: I just installed my k04 Turbo at home!
good job man, glad the install went well. ill be the first to say:
[sm=ttiwwp.gif]
hiwords's Avatar
good job man. also hang on to that old one and see if you can sell it. someone might buy one for a rebuild or something.
Old 12-10-2007, 11:30 AM
blake's Avatar
So far even with out a chip, the car seems faster. Its snowed here so cant go to fast.
Upsolute chip is what im thinking of going with.
K04, test pipe, 5 bar fpr and 180 degree fan switch. What kind of numbers should i be expecting?
Old 12-10-2007, 12:10 PM
Audi_Skydiver's Avatar
What is the 180 degree fan switch??? Never heard of that one.
Josh
Old 12-10-2007, 12:56 PM
rsrbljan's Avatar
changing a stat to a lower temperature keeps the overall engine temps down. I'm assuming (and you know what happens) that he's changed the fan switch to 180*to have the fan kick on sooner, thus lowering the overall coolant system temp.
I don't know why you would do this at the fan though. I always did it with a change of the physical thermostat. I generally used a 160* stat, and then drilled holes in the lip of it, so some coolant was always flowing. the cooler temps kept the system from inducing KR (knock retard) and pulling timing.
In my 1/4 mile cars, we never used stats. Just a big *** washer. that way when you cut hard from the line, there isn't a delay in getting coolant to the heated cylinder walls. a big surge of cool antifreeze on a hot cylinder wall CAN cause an engine failure. Think cold water on a piece of hot metal... just inside your engine while moving at 6k RPMs.
ok I've rambled enough...
ps - doing so on a street car results in engines that never get up to tmep and reduces gas mileage, poor performance, and can be a cause of detonation.
-Ryan
Old 12-10-2007, 12:58 PM
cincyTT's Avatar
I'm make believe
going with upsolute is like strapping a bomb to your car and starting the timer.... But good luck!
Old 12-10-2007, 01:29 PM
A4speed's Avatar
ORIGINAL: blake
I would go with GIAC with the k04.
Old 12-10-2007, 01:30 PM
klum00's Avatar
the switch keeps the fan running at a lower engine temp. basically acts as a turbo timer for you...
Old 12-10-2007, 02:39 PM
AUDI05's Avatar
ORIGINAL: A4speed
[sm=ttiwwp.gif]
lets me second this!!!!
Quick Reply: I just installed my k04 Turbo at home!
