I have a 2003 Audi A4 with problems Help
I'am fixing my brothers 2003 Audi A4. It has a check engine light, so I scaned it. It pulled two codes and here is what it read. First code was P0507 idle air control system rpm higher than expected. The second was P0706 Transmission range sensor circuit range/ performance???
RE: I have a 2003 Audi A4 with problems Help
i believe the 03 has a electronic throttle control. which means the idle air control is on the throttle body. try cleaning the throttle body with throttle body cleaner and see wut happens. and do a search. i think there was sum1 who had the same problem and had to change their throttle body
cmulaisho
12-10-2006 01:24 AM
2001, 2003, 2006, a4, audi, body, code, electronic, p0507, problems, range, rangeperformance, sensor, throttle, transmission
