I AM RETARDED
RE: I AM RETARDED
the 710n is the stock 225hp tt, it holds more boost then stock some people like them because they are a cheaper alternative to the more expensive name brand's I have an Evo DV, our stock Dv's have a paper Diaphragm that is week and tears, the 710n is storger not sure if its paper or not. as for the n75 valve there are a few the J,K, and H comonly know as the race valce some of the programs require you to use them other dont, they tend to give you higher spikes but i have not really noticed any increas in over all boost in my set up with the non pc-16 ko4 file i just get some crazy spikes sometimes i see as high as 25 on a cool night..
RE: I AM RETARDED
right I get it ish cough but now turning to the air box &filter (would you go cone or panel) which ever how would you decide the pipe diameter to the throttle body?? if you go too large it effects the upper limit of torque and vica versa similar to taking the air box resonator away not to mention the exhaust??
RE: I AM RETARDED
ORIGINAL: JohnnyBravoA4
RE: I AM RETARDED
ORIGINAL: onepoint8tee
The stock DV and 710N both use a rubber diaphramm. No software "requires" you to use a different kind of N75 valve, unless its BT software which requires you to use a MBC... The software is designed to work within the parameters of whatever is already on the engine, unless its a BT and the boost needs to be manualy adjusted. People get differnt N75 valves because they have different affects on the wastegate for the turbo which can result in smoother boost delivery/spiking elimination with an added 1 or 2 psi.
and with my n75 h valve i didnt gain any boost its smoother but i have some issues with boost surges
