I am Putting together a BT
#23
RE: I am Putting together a BT
ORIGINAL: gotaudi
Does anyone know anything on Oil/ coolant lines? I have been looking but no luck
#24
damn that thing is pretty cool
ORIGINAL: Redgoat
def get a PSI3
get a single din radio and plug this in below it.. (yes, they make them for Audi) You wont be disappointed.. and you can monitor everything thats going on with the car.. IE Lambda A/F Ratio, RPM, Boost, Coolant Temp, Road speed, Intake temp, so much more!!! It is worth the money, because you can always look to see if something is going on with the car
def get a PSI3
#25
http://www.psi3.co.uk/index.php?act=viewDoc&docId=1
check around the website there also if you look under the downloads section you can see the flash demo of how one of them works.. btw, it shows it in bar and celsius etc.. you can always switch that around to PSI etc.. they are about 325 pounds i believe.. but you can also use it to read and clear your fault codes and they just plug into your OBDII port
#26
damn its kinda like a mounted VAG-com
ORIGINAL: Redgoat
#27
yeah it is.. i love it!!! (My sig says Forge in dash VAG) that is what its referring to.. also you can get the Carbon Fiber faceplate for it. ( i have it and love it!) i would recommend this to anyone doing a turbo upgrade.. not sure where exactly they sell them in the states still.. but i sent them an email asking.. hopefully i get a response
#28
hey, good luck on the bt! nice car!
not to be a thread stealer but,
puttin a bt on a 01 1.8, would be tricky rite, being a dbw and everything?
wuts the best software for a gtrs elim
i kno its not smart to put one on, but i heard of a non dbw converter? is that rite?
thanks alot!
thanks alot!
#29
yea you can buy a conversion through 034efi I think and run 034efi standalone on your car, you can BT your car its just more work
ORIGINAL: Quarter106
thanks alot!
thanks alot!
