HUGE PROBLEM!
HUGE PROBLEM!
I got a huge problem my Cars speedometer stopped working suddenly and the gas keeps going up and down like crazy, i dont know if its due to the fact that my friend accidentaly put 10 bucks of reg gas on it and then put 10 os super can anyone help i need help quick.
RE: HUGE PROBLEM!
well as wierd of a problem that is it has nothing to do with the type of gas that was put in the car, have your battery and alternator checked, all those gauges operate on principle of magnetic attraction and repultion so if you arnt getting proper charge or voltage will make the gauges flip out.
RE: HUGE PROBLEM!
damn so it could be either one? It just stopped suddenly though like out of nowhere. Anything else u guys have for me? Could it be anything with a fuse or not please i need all the help i can get.
RE: HUGE PROBLEM!
that happened to me.. except it was all my guages acting up, and the car would die... turns out it was a really bad alternator and battery, got those switched... and bam... just like that it worked again!
RE: HUGE PROBLEM!
ORIGINAL: Aliel
If its only your speedometer and your gas gauge its not the alternator. I remember it took my mechanic a couple of hours to find the messed up wire and he charged me labor only.
RE: HUGE PROBLEM!
A way you could check your alternator yourself is crank the engine and disconnect the battery. If the car continues running, then your alternator should be fine. If not, you know you need a new one. Then check the battery. It should be around 14v when running and around 12v off. Good luck in finding your problem.
RE: HUGE PROBLEM!
Actually now that you guys mentioned it i did put two piece projectors in about two months ago but did nothing to the wiring. Also I had an indash installed about a year ago so i really dont know what the problem could be. My friend also told me to check the alternator by letting it crank and disconnecting the positive and if it runs for more than a minute then the alternator is not the problem. And he also adviced me that it could be a bad ground. Thanks for all the help fellas. Let me know if you have anything else for me.
