How much should it cost to flush and fill all three diffs?
I was quoted 200 bux including some really nice synthetic racing fluid... This is from a really nice shop that is known to charge a little bit more then anyone else (give a good warranty on all work and parts done)...
SMo'
SMo'
RE: How much should it cost to flush and fill all three diffs?
ORIGINAL: onepoint8tee
Free.95 DIY Minus the cost of the REALLY NICE fluid.
SMo'
Should be pretty obvious.. Drain plug, fill plug for the center? For the rear you probably have to take part of the bell housing/pumpkin off to drain (will need new gasket) and then put it back on and fill through check plug until it overflows. Not real sure i dont have quattro [:@]
Try a search?
Try a search?
Yea' I searched here and audiworld...
I would rather siphon it out of the rear diff (every diff really, to make sure I got it all out)then take it all apart...New sealswould be nice but I just dont have the patience for that right now...
SMo'
SMo'
There is also plugs for the rear.....It can be real hard tho......if you cross thread aplug (that's all I can think of tho). The dealership charges more than that I believe.
JHSimmons
08-29-2013 12:56 PM
