Sponsored by:
Sponsored by:
View Poll Results: A poll
Uses K&N air filter and I have no issue with MAF
73.68%
Uses K&N air filter and I have a problem with MAF
10.53%
Uses K&N and changed to paper filter
10.53%
Never really like the K&N filter
5.26%
Voters: 19. You may not vote on this poll
How many here uses K&N air filter and changed it to paper?
Old 10-08-2005, 03:16 PM
dudley doright's Avatar
Default How many here uses K&N air filter and changed it to paper?
I just wanted to take a poll on the number of people using K&N and having some issue.
Old 10-08-2005, 03:56 PM
flyboy's Avatar
Default RE: How many here uses K&N air filter and changed it to paper?
yeah I have an issue, It does what it says, now if you over oil it, you might run ito a prob, but from actuall experiance I'v found it to flow better than no airfiltr at all. I had the K&N volocity smothing thing on my holley four barrel on my V8. I was setting the idel mixture with a vacume gauge (the way you can do this) Once I had that set I put the airfilter back on and drove over to my friends place about 10 miles away and noted that the car was running ruff. I go the gauge back out and had to fatten up the mixtur by a full turn on each side, hense more air, needs more fuel.
Old 10-08-2005, 05:29 PM
skidplatexa4's Avatar
I've had one since I first bought my car and never had an issue. Don't over oil it I've also had one in every other car I've owned, and I even have one sitting on my bench in my garage for my 70 GTO. That's another story though for a later time.
Old 10-08-2005, 08:10 PM
rowingdude's Avatar
I bought the LLTEK intake..
Old 10-08-2005, 09:54 PM
headshok2002's Avatar
I switched back to paper last week. My K&N is on my shelf.
I figure for the 2hp I've lost... I can sleep better knowing my MAF is safe.
Old 10-08-2005, 10:33 PM
Which paper filter did you buy? Did you get the OEM or the Fram filter?
Old 10-08-2005, 11:39 PM
ecksman's Avatar
i use a k&n and just recentley oiled, i pretty sure i over oiled it what does it do to the maf, is something that takes one f*** up or over a couple of f ups
Old 10-08-2005, 11:55 PM
one **** up could do it... the oil coats the maf, and it stops working.
I used the OEM filter. Fram air hogs are oiled as well.
Old 10-09-2005, 12:04 AM
flyboy's Avatar
has anyone called K&N about this. they might have a suggestion and if not, I would ask for my money back.
Old 10-09-2005, 12:10 AM
I would ask for a go at their daughter(s).
Quick Reply: How many here uses K&N air filter and changed it to paper?
