how do i install a diverter valve
RE: how do i install a diverter valve
Might want to hit up a search on that one.. its one of the most hit topics.. its not hard, and im sure there isa DIY on one of the boards.. also dont run a BOV you will get flamed to high heaven for that.. it should only take an hour at most to change the DV for a first timer.. when you take you stock one out make sure you note how it came off so you can put the new one in the same way..
in order to do it right, the bentley manual shows it as a 3-step process:
1. take off old one
2. put on new one
3. keep it real
the 4th step: "4. break 'em off a lil' somethin'-somethin" is optional and completely up to you.
1. take off old one
2. put on new one
3. keep it real
ORIGINAL: oh1a4
1. take off old one
2. put on new one
3. keep it real
1. take off old one
2. put on new one
3. keep it real
any pics of puff-puff-give?
on a serious note, to help out a serviceman, you will need to at least take the belly pan off. of course the best time to do it is when you have it either all cracked open or at least in service position (= front bumper off) as in the post above. at the very least put it up on stands and take the belly pan off.
I thought it was "puff-puff pass" and dont n-lip it..
ORIGINAL: onepoint8tee
You mean a tipped 40 for thefailed TB tensioners?
I think the first step in the TB procedure starts out with "puff-puff give"
