how to bore maf sensor in 2.8
RE: how to bore maf sensor in 2.8
What is the id and od or the maf? Modshack sells bored out ones for the 180 and 225 mafs. You will need to add additional fuel to accomindate for the extra air, increased fuel pressure will be enough.
ORIGINAL: Trey25
Yea but the hp gain, if any, will not be significant.
Ugh - 1.8t owners - step off
You can DIY your MAF if it's a 471A model. All you have to do is take out the thing in the middle of the MAF housing. Easier said then done. I bought a Mance S3 MAF and it does add a bit of fun factor.
The 12v runs a bit rich by nature so taking out the post shouldn't cause any problems.
