HOT WEATHER 100+ DEGREES. 2.8 30V OIL SUGGESTIONS...
yo, i live in phoenix, arizona... the hottest part of the united states, lol. we see temperatures of 120 degrees on a normal bases in the summer, should i still be running 5w-30 mobile one synthetic?? I have heard when the weather gets hot to change oils.. i searched but found nothing but info for the 1.8, lemme know whats up and ill go from there, thanx players lol...
tim
tim
RE: HOT WEATHER 100+ DEGREES. 2.8 30V OIL SUGGESTIONS...
Check out the owners manual under oil. You will see a graph with different oil grades vs temperature in there. Looking around on the site you will see all the 1.8T guys talking about 0-40 or whatever they use.
I am in SC which doesn't get as hot as AZ, but doesn't get really cold either. I posted a similar question and was told to use the manual. There are several options for the higher temperature climates. I personally use Mobil 1 Synthetic 15W-50.
0w40 or 5w40
The 40 part means it stays thicker at the higher temps, giving better protection.
maybe do a water/meth injection to keep the intake cooled down in the heat.
nya4
10-01-2008 07:00 PM
