which hose is this?
which hose is this?
ok looking at the engine it is on the right and it bends around the manifold (top right corner) and is shaped like an upside down L. runs right next to the coolant resevoir. wish i had a camera... mine has a tear in it and is leaking right on the corner. it looks like the hose goes to the resevoir behind the firewall (i think). and then into the manifold? where can i get one? how much? how bad is it that it has a tear? issues? can i DIY replace? thanks for any info.
also does anyone have a DIY on a turbo inlet hose?
thanks guys.
thanks guys.
RE: which hose is this?
is that like power steering? or brake fluid or what? any idea? can I DIY without stuff leaking all over the place?
I'm buying this https://www.audiforums.com/m_319667/tm.htm
ORIGINAL: smokeU
yeah i figured it would be easy once I got it all apart. Thanks bro. do you think the tear in that hose could be causing the wooshing noise i've been hearing under boost? is that a descent hose for the price? will i see any difference in performance? or is it a useless mod?
ORIGINAL: smokeU
I have a 2001 and i just replaced that hose with some radiator hose i had it fits perfect. See that hose is not reinforced so under high boost it will tear over time. you can go to the dealer it is not an expensive part. i noticed a huge increase in power after i eplaced the hose. with the x chip i was boosting 15 psi.... after i was spiking 21 and holding about 15psi at redline. my gas milege went up about 2mpg better. once you fix the hole or replace the hose you will see a difference.
where'd you get the radiator hose? any idea for a quick repair till i get a chance to replace (duck tape)? can you give me a quick walk through? will stuff leak if i just tear those clips off and replace or is there other steps that need to be taken?
