HOLY CRAP THE DEALER IS SPOKANE IS EXPENSIVE!!!!
I just called my local Audi Dealer to find out about the 710N DV and a bottle of coolent:
Bottle of Coolent- ECS Tuning -$10
- Stealership - $26
710N - ALMOST ANYWHERE ELSE - $30-35
- STEALERSHIP- $67!!!!
Stupid People. Guess I will just buy it on-line. Any of you have a 710 N that you want to sell me?
Josh
- Stealership - $26
Josh
RE: HOLY CRAP THE DEALER IS SPOKANE IS EXPENSIVE!!!!
I bet you could find a used Forge style dv for $50-$75. I think it would be worth a little extra compared to a new 710N. If you intend on doing a k04 sometime (which i think you do?) then I wouldnt use a 710N dv. From my experience they are only good up to 18ish psi. An agressive k04 file boosts more than that. My 710N dv died after about a full year of boosting 20 psi.
ORIGINAL: akielb
I favorite stealership story is when I went in to see how much a replacment BOSE 6.5inch rear deck woofer would be.....$210 dollars EACH!!!!
Josh
Welcome to Audi. My local is about the same, I paid $27 + tax for coolant, and when I first got the car, the CEL came on as I was leaving the dealership, it was the DV's & some other little things, they charged me 1.5hrs labor to change the DV's & $75 a piece for them. LEASON LEARNED!
Now I DIY, & only buy from the dealer when I have no other choice.
If you need a shop, I had Mechanic Masters over there, rebuild a very expensive, very high HP BMW engine for me, after it blew up @ Spokane Raceway.
Very good work, and they were cheap labor.
Moral of thread... Avoid dealer if possible. Some things you have no choice. I just paid $27 for a check valve not found anywhere else... Probably costed them about 50 centsto make and about 10 minutes in R&D time. Is pretty much robery.
ORIGINAL: onepoint8tee
Moral of thread... Avoid dealer if possible. Some things you have no choice. I just paid $27 for a check valve not found anywhere else... Probably costed them about 50 cents to make and about 10 minutes in R&D time. Is pretty much robery.
