Holiday Boost Gauge Install!
#41
RE: Holiday Boost Gauge Install!
fix that gauge or boost leak yet? If not, while at AutoZone, pick up the Autometer Ultralite boost gauge. I have had no problems with mine at all, just zip tiethe vaccum line to theT-fittingdown tight and you should be fine.
#42
I talked to my brakes teacher today (I am taking automotive classes) and i talked to him about my vacuum leak. The school has a smoker that you put into the vacuum lines to try to find the leak(s) so I am going to do that on Thursday. I will let you guys know the results.
#43
i hooked up the smoker today and there was smoke coming out of my carbonio intake box, this means one of two things:
A vacuum line is cracked by the intake
or
It made it all the way through and is coming out of the intake filter, which means my boost gauge isn't the greatest
Also, a guy in my class and my teacher both said my Hg level could be lower here because I am at 4800ft altitude, would you guys agree with that? So in the next couple days I will take apart my carbonio intake and try to locate a broken vacuum line.
or
