HKS SSQV Blow Off Valve Kit for audi?
Old 12-05-2007 | 12:26 AM
AUDI05's Avatar
Default HKS SSQV Blow Off Valve Kit for audi?
I was re-searching the HKS SSQV Blow off valve, and have a question. I see that say audi drivers could purchase the universal blow-off valve. But then what mounting hardware and such others things do you need to purchase to install it? Im looking for a diverter valve that will give me some squeak : ) although i know that most fellow audi drivers don't support that : (
Old 12-05-2007 | 12:39 AM
cincyTT's Avatar
I'm make believe
Default RE: HKS SSQV Blow Off Valve Kit for audi?
its not going to be louder than any other dv when recirculated. Plus its $250 for the valve and another $50 or so for the new fittings to make it fit the stock locations. Dont waste your time or money to have it recirc. Plus if you vta, tha ssqv is REALLY annoying. That valve gets old in like a week. Get a forge004 if you want a bov
Old 12-05-2007 | 12:42 AM
AUDI05's Avatar
now whats the difference between a forge004 and a forge 007 thats everyone seems to be buzzing about?
Old 12-05-2007 | 12:44 AM
cincyTT's Avatar
I'm make believe
the 007 is a dv that is built like the stock bosch 710 but uses a piston design for durability. The 004 is a twin piston bov that can not recirculate and works well with vag cars.
Old 12-05-2007 | 12:49 AM
AUDI05's Avatar
thanks cincy. I have a 2005 B6 1.8T. could you help me find the valve on line and everything I need to hook it up? im searching right now with little luck
Old 12-05-2007 | 12:50 AM
cincyTT's Avatar
I'm make believe
ecstuning.com, go under your make/model and then intakes. Everything on there will work with your car. The top bov is the 004
Old 12-05-2007 | 01:03 AM
AUDI05's Avatar
im seeing the APR R1 Diverter Valve as the top one.. the forge 004 isnt there
click here
Old 12-05-2007 | 01:53 AM
littleflavio's Avatar
cincy...is it true that the bov can damage my car? i dont have any mods in my car, if ever i did put one without any mods will it run just fine for stock?
Old 12-05-2007 | 02:08 AM
sdboarder84's Avatar
Get the forge 004. I have had mine now for a few months and love it.
in response to littleflavio it can only damage your car if you run a certain type on a pre 99 car. There are two kinds of BOVs ones that leak air in to the atmosphere at idle and ones that don't. This is porblematic on pre 99 cars because they can not adjust for the lack of air causing the car to run lean. Moral of the story if you want to run a BOV get a Forgee 004. yes it will run fine, just will not be that loud.
Old 12-05-2007 | 02:11 AM
thanks...so ur tryng to say that its gana run fine with my b6?
Quick Reply: HKS SSQV Blow Off Valve Kit for audi?
