Hitting higher RPM's after K&N 57i install
Old 07-16-2007 | 02:54 PM
A4 Effort's Avatar
Default Hitting higher RPM's after K&N 57i install
I recently installed aK&N 57i intake on my '99 and noticed thatwhen i mash the gas pedal and it hits the "passing gear" that my RPM's are hitting up into the 5k range and then coming back down. I didn't notice this prior to the 57i install, so i was wondering if this is a by-product of going with this intake,or is something starting to rear its ugly head?
I just changed the plugs yesterday to NGK Iridium IX, so is there something else i should be checking? Throttle body maybe?
fyi - 2.8 w/tippy
fyi2 - hitting 5k with that intake on sounds pretty good tho
Old 07-16-2007 | 03:12 PM
ironman's Avatar
Default RE: Hitting higher RPM's after K&N 57i install
do you notice anything slipping, it may jsut be your engine can excellerate better due to more air, and your tranny mod not shifting as fast.
Old 07-16-2007 | 04:12 PM
A4 Effort's Avatar
Nope, can't say i really feel anything slipping. Your ideology of the engine breathing better makes sense, which of course is why i put the intake on to begin with. I'm probably worrying over nothing, but wanted to double-check to see if maybe something in the car was on its way out.
AudiTurbo
06-19-2013 06:58 PM
gmann00089
11-20-2008 02:26 AM
Prizmatik
09-23-2008 06:26 PM
auditt225
04-15-2007 05:59 AM
David_K
08-12-2004 02:41 PM
