Sponsored by:
Sponsored by:
HID - Not so bright!!
Old 09-16-2007, 11:26 PM
Trey25's Avatar
Default RE: HID - Not so bright!!
if the light is faded most likely its the bulb. Switch them to make sure. If not then its the ballast.
Old 01-22-2008, 09:24 PM
bronxblaza117's Avatar
how do you clean the projectors?
Old 01-22-2008, 11:32 PM
ImTheDevil's Avatar
It's a pain but it can be done. I did it on another car by removing the headlight bulb and the housing itself from the car. I wrapped/taped a shop towel on a thin dowel, doused it in alcohol, and put it in through the bulb opening to swab out the inside of the lens..
Old 01-23-2008, 12:29 AM
apr_a4's Avatar
did u touch the bulB with youre fingers?
Old 01-23-2008, 12:54 AM
01A4T's Avatar
ORIGINAL: apr_a4
If he touched the bulb with his fingers, that would most likely cause the bulb to burn out very quickly. I bet it just isin't aimed correctly.
kwaskow
01-06-2012 04:11 PM
A4Ash
04-21-2010 10:09 AM
h8state
11-27-2007 06:55 PM
stryker
10-26-2007 07:30 AM
mikejaeggi
05-29-2007 01:15 PM
Quick Reply: HID - Not so bright!!
