hi guys... its me, problem audi again
Old 05-27-2005 | 01:45 PM
pliddy's Avatar
Default hi guys... its me, problem audi again
what are some signs that a clutch is going bad? i am currently at 107k miles, and am not sure if they ever changed the clutch. 96 audi 2.8
when driven hard, car seems to hesitate for a sec... is that a sign of going clutch? man this car has sooo many problems... and OEM parts are so $$, that i think i might mod my car, just for price sake.
also seems like my car is getting slower and slower..
so with that,
what kind of clutch is a good cheap replacement to stock?
since im doing that, what is a good exhaust that will give me some hp, but not much noise? i dont like the racer exhaust sound...
and since ill do that, what is a good cheap intake for this car? thanks guys...
maybe if i treat the car as a toy, it will last longer and run better. So far, babying it has done notrhing but cost $$$
Old 05-27-2005 | 02:03 PM
headshok2002's Avatar
Default RE: hi guys... its me, problem audi again
intake: do it yourself
exhaust: personal preferance (but why mod a 12V)
your loss of power: try a fuel system cleaner, and if they havent been done recently, check your plugs/wires
clutch: watch your revs... is this "hesitation" you feel accompanied with your RPM's climbing?
If not, hesitation could be a result of the other things I mentioned... might be helped with plugs/wires.
Old 05-27-2005 | 02:35 PM
pliddy's Avatar
i will try a cleaner.. just did new plugs and wires..
i will check for rpm when the hesitation comes..
waht u mean do it yourself intake?
Old 05-27-2005 | 02:39 PM
check... audiworld I think, search the archives... there is a DIY intake mod
Old 05-27-2005 | 03:20 PM
hb972.8q's Avatar
ORIGINAL: headshok2002
we as 12vers might not get many gains out of our mods but like any outher person we like to mod the car we have.
Old 05-27-2005 | 03:27 PM
jaustin's Avatar
Member
um are you using 91+ gas?
check the pressure in yoru tires?
alignment?
as for the clutch you will notice it doesnt shift into gears as smoth as it once did (at least thats how mine went)
Old 05-27-2005 | 03:32 PM
pliddy's Avatar
i use 89..... is that bad?????
Old 05-27-2005 | 03:41 PM
jaustin's Avatar
Member
um you should pry use 91 or better at least that what it says in my car you will also get better MPG with 91+
Old 05-27-2005 | 03:45 PM
hb972.8q's Avatar
ORIGINAL: pliddy
if you are going down the street say 30mph put it in 5th and floor it. it the tack climbs faster than your speedo then you are looking to buy a new clutch. i got mine from spec ...stage 2 spec
you should try seafoam look it up on aw in the 12v development forum here
so with that,
just go to a local custum exhaust shop and thell them what you want
k&n drop in filter is good or you could pick a cheep cone intake off ebay not much power gains form both but 2nd one makes some nice sucking sounds.
thanks guys...
for lots of info on 12v's look here
Old 05-27-2005 | 03:48 PM
hb972.8q's Avatar
ORIGINAL: pliddy
i always used 93. have you changed you fuel filter? if not look into geting it done should not be to much
