help on some obdII codes ??
Old 05-28-2007 | 04:27 PM
audi_a4_guap's Avatar
Default help on some obdII codes ??
Two things ...im driving a 97 a4 1.8t quattro and i have a couple codes and im not really sure what i need to fix P1136 something to do with air fuel and P1559 something about idle speed and i have the haynes manual for my car and it doesnt give me a fusebox layout and mine was ripped out of my manual that came with the car anyone know where i can get that ??? thanx
Old 05-28-2007 | 04:45 PM
techbod's Avatar
Default RE: help on some obdII codes ??
P1559 = throttle control unit - basic setting malfunction problem was accelerator pedal or starter motor operated during basic setting,
P1136 = long term fuel trim, idling, bank 1 - system too lean problem could have been caused by the other code or there is an air leak in the vacuum system or AIR system
Old 05-28-2007 | 04:51 PM
theguy1084's Avatar
I would look for a vacuum leak. Sometimes if the leak is big enough it will throw a code for the throttle because the throttle can not compensate for the air leak. Just check all of the vac lines and breather lines for leaks.
Bklynrx7
09-23-2010 12:19 PM
bonito69
08-19-2009 11:30 PM
chefro
01-30-2009 03:22 AM
forgottenmindset
07-19-2008 03:33 AM
schaedj
08-29-2005 11:36 AM
