Help! Power loss + bad noises
B5 A4 1.8t automatic/tiptronic, only things done to it are a APR chip and a K&N filter (the filter I just put it the day before)
So I'm driving as normal, put my foot down on the gas a little bit, and I hear a terrible sliding/grinding noise. My car still runs (I guess) meaning it'll start, go forward and shift gears, but there is a noise that sounds like the sounds a go cart engine makes coming from the area around the turbo. The car's loss of power is incredibly great; it's as if I am literally driving a bad go-cart. I drove it a mile home, and it smelled as if the exhaust isn't doing it's job (started smelling the gases in the cab).
Anything? I haven't taken it to a mechanic yet because I have to go out of town for a few days, just seeing if anyone knew what it might be before I do.
RE: Help! Power loss + bad noises
Thought it might be a blown turbo.
I don't feel anything different except for when I try to accelerate it put-puts so sloudly I let off for fear of breaking it more. No vibrations or anything apart from the noise and the power loss.
ORIGINAL: cyberlogicx
Blown turbo!
Blown turbo!
The turbo is not blown....relax. If it was blown, you and your entire block would know. The main cause is most likely a blown turbo to manifold gasket. It kill the spool/power, smells like exhaust fumes, and makes the car louder. If you can do simple jobs on your car, you can remove/loosenthe manifold and remove the blown gasket and reinstall everything with no gasket after you clean the serfaces.
Awesome, thanks man. I was worried my car might be dead because I couldn't afford to fix a turbo blowout... So you're saying just remove the gasket and reinstall everything without a new one?
Otherwise I'll get a leak, right? Assuming I just wanted to shell out the cash for a new gasket, how much are they and what part exactly would I need?
Btw, thanks for everyone's help. It's greatly appreciated.
steven.whyte
03-15-2012 11:53 AM
viper_04649
12-15-2008 09:10 PM
