Sponsored by:
Sponsored by:
help please please I'm trying to run boost gage lines to the engine bay
Old 01-24-2005, 11:00 PM
aaronamericahall's Avatar
Default help please please I'm trying to run boost gage lines to the engine bay
I've been try to run the dam wires and hose for my boost gage for the last 2 hours but I can't figure out how to get the lines ran to the outside of the car to the engine bay I found that one rubber seal that I thought goes to the outside but when I stick the hose through I can't find it on the outside anywhere help help help
Old 01-24-2005, 11:21 PM
audiboy1618's Avatar
Default RE: help please please I'm trying to run boost gage lines to the engine bay
Go down through the back of the ecu box and up there through, thats what i did.
Old 01-25-2005, 12:53 AM
thats the only way with out drlling through the firwall. make sure you put heast shrink tubing over the line so it wont mealt
Old 01-25-2005, 01:05 AM
brrman's Avatar
yeah the ecu box is the best way. 99% of us do it that way. I also believe there is a grommet for the Hood release wire somewhere, though I have never looked hard enough to find it.
Old 01-25-2005, 01:12 AM
it's right by the hood release
Old 01-25-2005, 01:43 AM
brrman's Avatar
heh heh - damn - the only place I didn;t look!
Old 01-25-2005, 01:49 AM
thanks everyone for the help now I have the hose ran through the ecu box and now I just need to get the heast and the T connector I can't seem to find a T as small as this hose though
Old 01-25-2005, 02:39 AM
brrman's Avatar
Sears or Ace hardware carries them for 65 cents.
Old 01-25-2005, 03:21 AM
trailboss's Avatar
brrman, doesn't that hose tee cause the boost gauge to make a buzzing sound when making boost? Mine does and i had a metal hose tee and i think i remember it didn't, but i swithed it out with a plastic one because i thought it was leaking. I didn't have a metal hose tee i had a metal compression union that was a T and i though it wasn't sealing good so i switched it out.
Old 01-25-2005, 04:32 AM
you did it wrong.
Quick Reply: help please please I'm trying to run boost gage lines to the engine bay
