Help Needed
Help Needed
My car won't start this morning, so i brought it to Les Schwab to change a new battery.
Here is the problem:
1) The battery they gave me is different in physical size, it is smaller than the old one, they insist it has no differences other than the size
2) Can someone give me the specs to the original Audi 2000 A4 1.8T battery? So that I can compare to the one they gave me.
Thanks alot guys!
Say
Thanks alot guys!
Say
RE: Help Needed
It is Les Schwab 47 XT Xtreme Power Battery, the right size should be Les Sschwab 48, but they do not have it, and say 47 is the same.
When i turn the key to the first position, before ignition, the battery meter shows 12 volts, when i started the engine, it shows around 14-15 volts. Does this sound right?
Thanks.
Thanks.
desertsnake1991
08-28-2012 11:07 AM
