HELP! Loud Tapping From Engine
#31
RE: HELP! Loud Tapping From Engine
ORIGINAL: ak audi
I've had the car for 2 months. A CarFax report is supposed to be faxed to me this morning. I'm at work right now and didn't drive the Audi. Will work on the sound clip as soon as I get home.
#32
No loss of power and no rough idle, it zips right along just like it did prior to the noise. The guy that's faxing the report to me did remember the car was originally bought in Connecticut.
#35
I had an oild change yesterday, the only synthetic they had was 0-40W. Should I do another oil change with 5-30W? Does anyone know how/where to check the tranny fluid? The guy at the garage couldn't even find it.
#36
there can't be too many dealerships in connecticut, contact them and see if you can locate a previous owner. you should really try to find as much info as possible about the maintenance of this car...even if your t-belt was replaced once, you may be coming up on your second tb change. the carfax report will help you track the car's history, hopefully that'll give you a lead or two for finding a previous owner. the tb change is not difficult, just time consuming. i've never seen a rear tensioner job done so i can't comment on that, but that definitely sounds like your noise problem.
#37
ORIGINAL: ak audi
