HELP IM GETTING THE RUN AROUND!!!! this sound is weird
okay well the situation is i have this sound thats coming from either mid under the car or the front of the car, at first it sounded like a broken heat shield on an exhaust, which when i took to the mechanic he said it doesnt exist with audis.. or maybe just my audi... now his telling me all this other stuff it "mite" be in other words, ways to raise him funds... i keep getting different opinions, after listening carefully ive noticed this sound only comes when the cars under load, such as taking off , or the beginning of first two gears only. once driving at a steady speed you cant hear it... it sounds exactly like a broken heat shield but isnt what could it be helppppp pleaseeeee????
RE: HELP IM GETTING THE RUN AROUND!!!! this sound is weird
Take the mechanic for a ride in the car, and show him exactly what the noise is, and what causes it.
I the mechanic is having difficulty diagnosing it in person, we will have more difficulty over the internet.
You haven't told use anything about your car... I assume it is an A4 as you are posting to this grouo, but what is the year, engine, transmission, FWD or Quattro. Could be as simple as tire tread, could be wheel bearing, could be CV joint, could be something more serious.
Enquiring minds want to know.
sorry about the lack of details, its an a4 (b5), 1.8L non-turbo, auto, FWD. anytips?
also i dont know if i have cruise control, i have the switches there and the set button, but it doesnt work, i checked fuse box and theres no fuse in item 11, which is for cruise control... when i try put a fuse in, it just slides out, does that mean i have no cruise control and the switches are there for display?
any help is apreciated, thanx.
i had a very similar sound. it was in first gear only. it was made louder by puting strain on it I.E. going up a steep hill in 1st. found out my first gear had a chip in it (a tooth or two missing). i have a manual . had to replace my tranny. not cheep. hopefuly it is not this
good luck
harry b
good luck
harry b
well after taking it to several mechanics they say its the tension pully which is located near the front of the car, this hopefully isnt expensive, does anyone know if any other car makes use that same pully? just trying to save money
I have a similar problem like that i have a 2001 1.8t Q. in my first and secoond gear when acceleration kind of slow around 2 rpm i have a sound that sounds like a heat sheild hitting something.
great now ive had 2 different mechanics tell me two diffferent things...
1) driver side engine mount is broken, which may be causing vibration noise
2) exhaust leak may be causing this noise... hmmmm
any one who has had this problem please advice.. thanx
