Sponsored by:
Sponsored by:
help.. if anyone knows it vibrates!!
Old 01-16-2008, 11:36 AM
kakashisan's Avatar
Default help.. if anyone knows it vibrates!!
well i have this problem with my audi a4 1.8t 04 it vibrates like a crazy, only when i press the gas but when i let it go, the vibration stops if any one can help me by telling me what's the problem thank you ,, ooh this doesn't happen when the car is cold on when it heats up
Old 01-16-2008, 12:38 PM
veloracer's Avatar
Default RE: help.. if anyone knows it vibrates!!
Where are the vibrations coming from?
Old 01-16-2008, 01:11 PM
FASTER's Avatar
Tech Slut
does it have power loss? does the check engine light come on or flash? coil packs are common troublemakers
Old 01-16-2008, 01:39 PM
kakashisan's Avatar
well the thing is the vibration is only when is moving, but if you accelerate when the car is in parking it doesn't vibrate or anything and yes engine light is on does not flash
Old 01-16-2008, 01:41 PM
check for fault codes and check engine mounts
Old 01-16-2008, 01:43 PM
turbo kraut's Avatar
Tech Guru
ORIGINAL: techbod
Old 01-16-2008, 01:50 PM
FASTER's Avatar
Tech Slut
it wont misfire unless under load, and often times when the car is cold, they will be fine. get your codes pulled, i bet you have a misfire
Old 01-16-2008, 02:12 PM
kakashisan's Avatar
it's not misfiring it only vibrates i don't lose any kind of power is the same it only vibrates when is moving
Old 01-16-2008, 02:13 PM
FASTER's Avatar
Tech Slut
go get your codes read.... im sick of you already....
Old 01-16-2008, 02:17 PM
the reason for engine mounts is to prevent this happening ( when the car is under load the engine is forced to tilt ) a weak mount will cause vibration, a weak mount could be simply aged rubber or its bad
Quick Reply: help.. if anyone knows it vibrates!!
