help.. if anyone knows it vibrates!!
well i have this problem with my audi a4 1.8t 04 it vibrates like a crazy, only when i press the gas but when i let it go, the vibration stops if any one can help me by telling me what's the problem thank you ,, ooh this doesn't happen when the car is cold on when it heats up
RE: help.. if anyone knows it vibrates!!
well the thing is the vibration is only when is moving, but if you accelerate when the car is in parking it doesn't vibrate or anything and yes engine light is on does not flash
the reason for engine mounts is to prevent this happening ( when the car is under load the engine is forced to tilt ) a weak mount will cause vibration, a weak mount could be simply aged rubber or its bad
