HELP Bottomed out in Snow.
First problem, my fault.
Ok guys, i guess while i was drifting the other day itapeda huge pack of snow with my drivers side front end....or at least what i thought was snow. Apparantly it must have had some other things lying under. I was looking at my front end because i diddent like this gross little gap between the headlight and the hood and eventually i found a scratch on the front ends bottom plastic guard and that led to me seeing that that same peice had light scratches on it ditectly under the entire length of the guard and then THAT led me to find (hope you can follow) that the plastic guard that lies under the engine compartment that runs from the bumper was HANGING down very close to the road and FILLED with ICE....
I must have bottomed out on the snow, broken the tabs that hold that peice up, and then it must have filled with snow and slush from all the driving i did since.
This is very dangerous becausethe dam thing is loaded with at least 10pounds of ice pushing down on a huge plastic sheet that if it comes off im gonna run it over and kill myslef.
1. I need to know where the jack points are for the 98' 2.8 Quattro Manual so i can get the ice out
2. If the Plastic guard is busted do you think i can rehang it myslef?
3. This happen to any one before?
RE: HELP Bottomed out in Snow.
ORIGINAL: anmagro
well i like me some zip ties but zip tie it to what?
a control arm? isnt it saposed to be a frame point???
ORIGINAL: FasterA4ThanUrs
i wouldnt use the control arms to jack it up, the car should have a pinch weld right as the underbody is bending up, jack it from there...
ORIGINAL: bob12312357
Been doin it since i was 16, all the mechanic buddies i hang out with do it 2. No ill effects and its easy and convient 2 hit up.
Don't jack it by the control arms. Just behind the front wheels theres a spot between the pinch weld and the rest of the underbody that dips up. Put the jack there. Always use jack stands when getting under a car.
ORIGINAL: Lebe Frei
uh if youre talking about the plastic piece that covers the bottom of the engine bay and covers the oilpan and what notjust take that jank off you dont really need it haha
